Setting design layer properties
Command
Path
View bar
Shortcut
Organization
Tools
Layer Options
Ctrl+Shift+O (Windows)
Cmd+Shift+O (Mac)
Once created, the design layers display on the Design Layers tab of the Organization dialog box, where various properties can be set and edited.
To edit design layers:
Select the command, or click Layer Options on the View bar, and then select Show Organization Dialog Box.
The Organization dialog box opens.
Alternatively, to edit the active layer, click Layer Options on the View bar, and then select Edit Active Layer to open the Edit Design Layers dialog box and edit the parameters as described below.
Select the Design Layers tab.
A list of the current layers in the drawing displays in their stacking order. Depending on which view option is selected at the top of the dialog box, either details or visibilities of the design layers display. Stacking order, drawing area visibility, and active layer can be changed in Details view. The visibility of layers in viewports and in saved views can be changed in Visibilities view.
In the Vectorworks Architect and Landmark products, Details view includes any stories and story level types associated with the layer.
Layers that are imported from another file with layer import referencing display in italics. Position the cursor over the layer name to display a screen tip with the full layer name and the source file name.
To change other layer properties, select one or more layers and click Edit to open the Edit Design Layers dialog box.
Parameter
Description
Name
If one layer is selected, displays the layer's name, which can be edited
Description
Click to enter additional information about the design layer. The description displays as a screen tip when you position the cursor over the design layer name in the Organization dialog box, Navigation palette, or (on Mac only) the Layers list from the View bar. Descriptions also display in the New Design Layer dialog box, so that you can see descriptions of layers before you import them.
Scale
Sets the scale for the selected layer; see Changing the scale of selected design layers
Stacking Order
Changes the 2D stacking order of the layer; see Changing the design layer stacking order
Story
(Architect or Landmark required)
Associates the layer with a story; select the story from the list, or create a new story for the layer (see Creating and managing stories). Layers that are associated with story levels derive their elevation value from the associated level.
Story Level
Associates the layer with a story level; if the design layer needs to derive its elevation value from the associated story, select the appropriate level from the list of levels for the selected Story. The elevations for levels are displayed in brackets to assist with choosing the correct one. Alternatively, create a new level; see Default story levels.
Because a story level type can only be assigned with one design layer per story, we recommend assigning levels to story layers only when you need layer elevations to be controlled by the story. You can associate construction elements, such as walls and slabs, with story levels even if no design layer is associated with the level. If there are multiple design layers at the same elevation (for example 1-Floor and 1-Slab at elevation 0'0"), it's better to define the layer elevation relative to the story than to a story level.
Elevation
Sets the height of a layer relative to the ground plane.
For Vectorworks Architect or Landmark users, if the layer is associated with a story level, the elevation is set relative to the story and cannot be changed here.
The elevation relative to the ground plane also displays. For example, the second story of a building might be slightly offset from the story elevation, and also several feet above street level.
When a new layer is added to a drawing, its elevation values are automatically entered based on the previous layer's elevation and layer wall height values.
Layer Wall Height
Indicates the height of walls (and certain other objects such as columns) created on that layer, when the Top Bound option for those objects is set to Layer Wall Height
Cut Plane
Set the cut plane elevation; some objects on the layer, such as walls, can be set to use the layer's cut plane, ensuring a uniform cut plane appearance for the layer; see Concept: Cut planes in Vectorworks
Opacity
Controls how the selected layer and other visible layers display; on Windows, the Vectorworks display preference Use GDI+ imaging must be enabled
Transfer Mode
(Windows only)
Controls how the selected layer and other visible layers display; the Vectorworks display preference Use GDI+ imaging must be disabled; see Setting the design layer transfer mode
Colors
Specifies the default layer color for the selected layer.
A selected viewport data visualization (Design Suite product required) overrides this option.
Assign Tags
Opens a dialog box to assign tags to this layer for sorting and filtering purposes; see Filtering and tagging classes and layers
Saved Views
Specifies the visibility settings for the selected layer in each saved view; see Visibility columns
Viewports
Specifies the visibility settings for the selected layer in each viewport; visibilities set by a viewport style must be changed from the Edit Viewport Style dialog box. See Visibility columns and Creating and editing viewport styles.
Bind to Feature Service
Associates the layer with an online feature service with geographic features and data; see Binding a layer to a feature service
Setting the design layer opacity
Creating Renderworks backgrounds
Setting the design layer color
Setting up the building structure with stories
Wall display with design layer cut plane
